MFL
Aug 27, 2020Nomad II
You might give a little better description of the leak. Is it the actual water tank leaking, or maybe just a hose fitting, from the water inlet? A picture would help, if you can see where the leak is.
Jerry
Jerry
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
