surgtech56
Aug 28, 2020Explorer
mobeewan wrote:
Is the leak between the fitting and tank or the threads where the drain valve screws into the tank?
Is the fitting cracked and leaking from the threads?
It looks like both. I thought it was just from the threads but it looks like it’s also leaking between the fitting and the tank. I was going to put a hose clamp on the threads .
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
