bankerae's avatar
bankerae
AMP Draw Issues
Good morning Folks! I am hoping someone can point me in the right direction...
We have a 2005 Keystone Outback 26RS travel trailer and did our first dry camping last week. When the heat quit about 1:00am I knew something was not right :)
I just did an amp draw test and here is what I came up with:
Using a VOM meter set on the 10amp setting
with the power cord unlplugged and testing through the negative battery cable with everything turned on I was getting a .65 amp draw reading... after taking each fuse out one at a time here is what I found:
The 15amp fuse tied to the LP leak detector (may be powering other items too?) was pulling .08 amp
The 15amp fuse for the fridge (the fridge was turned off, however when I would put the fuse back in it would let out a loud beep) was drawing .54
When I tookt he fuse out for the fridge and the LP leak detector I was left with .03 amp draw
So there's the data, just not sure what it all means!
Thank you in advance for your help!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
