ajriding's avatar
ajriding
Explorer II
Aug 25, 2019
Hippajac Amp Draw
Anyone know the amperage draw of the power TC Hippajac lifts? For one or for four, but specify so we know…
I am wondering what amp charger controller to buy. 10 or 20? The lifts will be the biggest draw as I have another battery bank for the ele frig.
I guess I could wire the battery power straight to the fuse box, but usually the power would go through the charge controller and then to the fuse box.
Backstory. I have 200 watts going to a dedicated battery bank just for the frig. completely isolated from the rest of the camper.
The regular one battery in the camper will power everything else (Hippajac lifts, lights, fans, blower, phone and inverter which I have never yet used.) It has 100w solar charging it. I just ordered the parts, so will install soon.
Typical wiring is to have solar go to controller. Battery go to controller, and controller to output to the fuse box (load). Does it matter if I just send battery straight to the fuse box while at the same time straight to the battery terminals on the charge controller? Then the only amps to worry about would be the solar coming in, solar is low amps.
I dont want to pull the hippajac wiring to go to battery. Im trying to minimize the wire changes.
