cdcorpe's avatar
cdcorpe
Amp draw reading
I am trying to track down something that is drawing down my battery & I disconected the positive side of the battery & installed an amp meter in between the battery & the meter . My reading is .8 unless I cover my solar panels & then it drops to .3. I have gone thru all the fuses & nothing changes. Does this make sense ? The input charging amp reading on the solar controler reads 1.5 amps.
  • cdcorpe wrote:
    ...I disconected the positive side of the battery & installed an amp meter in between the battery & the meter .
    Hard to follow this sentence. What meter? Did you hook the positive back up?
  • smkettner wrote:
    .8 vs .3 is .5 amp so NO that does not reconcile with coving the panels and losing 1.5 amps. And not sure how you have .3 going in with no solar.
    I would check if that 1.5 amps is correct. Then disconnect the solar from the battery for the remainder of the tests.
    Are you using a multimeter in series? You may need 2 decimal resolution to find this issue.
    Yes I have the meter in series & I was just rounding off the amps. I am definitely confused, does the meter show only the amps being used, or a cobination of amps in (from solar) & amps used(Propane dector etc,)Thanks for the help. I have checked the batteries with a hydrometer & they are good. Thanks
  • .8 vs .3 is .5 amp so NO that does not reconcile with coving the panels and losing 1.5 amps. And not sure how you have .3 going in with no solar.
  • Has it got a shorted cell? That would kill a battery quickly. Take it to a battery place like intrstate or batteries plus they will test it for you free. ( Interstate will want the battery fully charged b 4 they will test it.)
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
