CA_Traveler
Dec 23, 2021Explorer III
The calculator adds about 15% due to loss of efficiency so 14.1A is reasonable for the calculator. However you need average input not maximum. AC appliances draw a lot of Ah (amp hours). The high efficiency Samsung 18 cu ft refer uses 100+ Ah per day.
Basically if you are going to use significant AC usage for devices then you'll need a very large battery bank, a large solar array AND a generator for those cloudy days. This is the reason most RVs to use propane for HW, MW, stove, refer and NO ACs for boondocking. Even propane for coffee!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
