Sort By
- GjacExplorer III
Bob Vaughn wrote:
That is what I am referring to. With nothing turned on and MH not plugged in .4 amps is my parasitic draw. Being plugged in should not affect the draw.Gjac wrote:
If nothing is turned on mine will draw .4 amps. Newer MH's will probably draw more. If you see more than 2 amps something is probably on. How much is your amp draw?
I am wondering about parasitic draw..... - Bob_VaughnExplorer
I am wondering about parasitic draw..... - BoomerwepsExplorerThe converter will run to keep your batteries charged. 14 watts or .1177 amps in my case with a charged battery. Did you turn off the fridge? Mine draws 328 watts or 2.7333 amps. Measured using a kil-a-watt.
- GjacExplorer IIIIf nothing is turned on mine will draw .4 amps. Newer MH's will probably draw more. If you see more than 2 amps something is probably on. How much is your amp draw?
- fj12ryderExplorer III0?
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 12, 2025
