Bob_Vaughn's avatar
Bob_Vaughn
Amp Draw
How many amps should a motor home draw when plugged in with nothing turned on?
  • Gjac's avatar
    Gjac
    Explorer III
    Bob Vaughn wrote:
    Gjac wrote:
    If nothing is turned on mine will draw .4 amps. Newer MH's will probably draw more. If you see more than 2 amps something is probably on. How much is your amp draw?
    I am wondering about parasitic draw.....
    That is what I am referring to. With nothing turned on and MH not plugged in .4 amps is my parasitic draw. Being plugged in should not affect the draw.
  • The converter will run to keep your batteries charged. 14 watts or .1177 amps in my case with a charged battery. Did you turn off the fridge? Mine draws 328 watts or 2.7333 amps. Measured using a kil-a-watt.
  • Gjac's avatar
    Gjac
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
