wa8yxm wrote:
RoyB wrote:
The rule of thumb is to have a charging source capable of producing those DC VOLTAGES listed here @ 15-18AMPS DC per battery in the bank. This is how many amps the battery will pull if you hit it with 14.4VDC. Around three hours later the battery will be at its 90% charge state. The charging current will drop back as the battery starts taking on charge.
So says the battery exports on here...
Roy Ken
You make a common mistake in the first sentence of this paragraph.
You assume there is one and only one 12 volt battery.. You forget that there is a lot of difference between say a group 24 where Depending on your intentions 7.5 to 22.5 are the recommended charge rates,, and an 8-D where 16 to 70 is the same recommendation.
One should never say just "12 volt battery" One should always say one of the following (As, I might add the original poster in this thread did so I'd like to congratulate him)
Size group 12 volt battery (O/P said 8-D 12 volt batteries)
Or: Amp hour 12 volt battery (C/20) (160 amp hour at the c/20 rate 12 volt batteries)
That way we can compare apples to apples
I mean which holds more amp hours? A pair of 12 volt batteries or a pair of Six Volt batteries.
Now, Reread what I typed and try to answer that question.. IF you choose the sixes, You will be wrong,,, If you choose the 12's. Likewise, For I hae not given you sufficient information to make that decision.
The OP stated: "I have a 4-D 12 volt battery in my fiver."
