Teamfour
Feb 02, 2014Explorer
BFL13 wrote:
Depends on your charger or inverter loads. Most RVs wire for just the charger amps like 55 amps or whatever your converter does so the 120 is plenty.
Note the wire size limit #4 to #10 where #4 is rated for 100amps. The 350 must allow way fatter wire.
Thanks! The 350 amp model is for 8,000 lb winches, so I would expect the wire size would probably be larger.
