time2roll
Jul 13, 2015Nomad
Yes and no. Yes the converter is capable of 55 amps. No a group 24 battery is not capable of accepting 55 amps for a full hour. Especially not at the top 20% of charge.
Any chance this is a WFCO converter? Measure the voltage to verify if you are getting boost mode 14.4 volts. If you only get 13.6 volts then amps will taper quickly and charging from low to 100% will take 12 to 24+ hours.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
