wolfe10
Oct 16, 2021Explorer
But, another way to look at it is how many amps are drawn from the battery.
If smaller gauge wire, instead of the vast majority of the amps turning the motor some are turned into HEAT by the resistance in the wire.
So, the answer really depends on how you phrase the question.
Bottom line is you want to maximize the amps taken out of the battery that are turned into RPM by the motor, not wasted in the wire.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
