icodeintx
Oct 11, 2020Explorer
AC Amp/Voltage monitor
Today I installed one of those "Amazon" amp meters. Mainly because I'm a pro at tripping the 30amp circuit. So I decided to install this thing so I can see my amps while different devices are running.
Lessons Learned:
The photo you see is actually upside-down. The meter is about 18 inches off the floor which is possible to bend down and see the numbers. However, the display range on the LCD is in the wrong direction for my application. This display was designed to be eye level or up high showing the numbers vividly. But when slightly above looking down one can only see a blank screen.
So smart me just turned it upside-down (for now) and when I bend over to look the numbers are actually right-side-up.
I love the monitor but don't really like the installation so I think I'll build a small installation box and mount the display inside the bench it is currently mounted in. Nevermind the unfinished bench. It is under construction.
Lessons Learned:
