wa8yxm
Oct 17, 2021Explorer III
The question on how much power (Amps) the furnace will draw is actually rather complex.. But in general I suspect the higher the voltage the greater the amps but it's not a 1:1 relationship also the faster the blower will blow which might result in greater comfort. But you cited a 0.2 volt drop.. NOT WORTH the cost of the wire to upgrade it for 0.2 volts. for 2 volts yes but 0.2 no.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
