pianotuna's avatar
pianotuna
Nomad III
Feb 26, 2015
an interesting solar charge controller/inverter
Hi,
For those of you with high utility rates this looks interesting!
Samlex solar controller and inverter
I wonder if it is able to be run in a hybrid manner?
"Explanation of Operating Logic
TN-1500 (CPU controlled inverter) is designed to achieve the goal of energy saving and possesses both UPS and Energy saving modes. These 2 modes are user adjustable. The unit will be factory set in the UPS mode. Depending on weather and utility conditions, users can manually adjust or use the monitoring software to switch to the Energy saving mode.
The main difference between UPS and Energy saving mode is the amount of energy conserved. Under the UPS mode, the unit will remain in the Bypass mode as long as utility is available. Thus less energy is conserved (refer to Fig. 4.1 for UPS mode control logic). Under the Energy saving mode, the priority of input source chosen is solar panel AC main battery. If available, the CPU will select external solar panels as its first priority in order to conserve energy. In case of insufficient solar power and utility failure, battery power will be drawn as the last resort. When the capacity of batteries is a round 10~20%, the CPU will remind end users by continuously sending out warning siren until the system shuts down."
  • Hi Mr. Wizard,
    It is still nice that the inverter/charger chooses solar first as a power source. I can see using such a device to power my laptop which is almost always on. I'm assuming the overhead from the inverter would be supplied directly from the panels.
    As it is a 30 amp pwm device it could handle up to 4 hundred watts. That would power the fridge, and still charge the battery bank between duty cycles.
    I'm unlikely to switch to this as I got the fancy Magnum.
  • Could be applicable to RV usage and the CPU doing the work makes it a cool addition. Unfortunately, most utilities in the USA require a separate relay and switch to separate any home owner generation from the grid. I don't see where this device can enable that. A guy could cobble up another relay to operate the disconnect-from-grid switch but utilities are very picky about hardware, some even choosing brand of disconnect.
  • Don
    Sounds like it switches between power sources, not hybrid syncing and adding too
