MrWizard wrote:
while thats true for weekends or part timing
get a big bank too low and you could spend a whole lot of time in bulk mode generator run time
with a 20% 12hr use (IF i did not charge during the day) i would be at 60% before bed tonight and 40% tomorrow morning
NOT the place i prefer to be
i can do that in a bad weather pinch, and the solar does mitigate the situation making it less strenuous than the straight math, and i could limit some of the power drain at night and make (2) with no charging
put that is winter time use, cool weather and no A/C, and less cooling strain on the fridge
different routines for different folks
Yes if you were at 40% the voltage would be much lower and I would recommend running the generator early to let the solar do the long absorption work later in the day.
In these conditions Magnum should run the voltage to 14.4+
