MrWizard wrote:
he just recently got an auto transformer for Boosting low voltage shore power conditions
but it sounds like he needs to 'BUCK Down' the generator output, because of the finicky Magum
Contrary to popular belief, auto transformers, being a single winding doesn't boost low voltage conditions. They are merely designed to be connected directly to the single winding with a center tap (or anywhere between extreme ends of the winding) depending on what output you would expect at the load end.
In order to boost the voltage, you would need a buck/boost transformer which is basically a two-winding transformer with primary and secondary windings. Some manufacturers sell a product they call autoformer which hasn't gained any traction especially who are familiar with transformers.
Besides,NEC (National Electrical Code) forbids autotransformers in RVs because of potential over voltage if a winding is open (burned portion of the coil).
