golf_bears's avatar
golf_bears
Anderson Valve Leak???
Tried a whole bunch of things to stop the fresh water tank from filling while hooked up to RV park water supply. Replaced the spool in the Anderson valve, replaced the entire Anderson valve, thought about replacing the water pump because the check valve is probably leaking. The pump works fine and is difficult to get at to replace.
I'm thinking of getting a 12 v DC water solenoid valve and putting it on the fresh water tank fill water line. The valve is normally closed so when hooked to RV park water supply no water will get into the tank. The fill line is also the suction line for the water pump.
Thinking of putting the solenoid in parallel with the water pump on/off switch. When pump is off the solenoid valve is closed. When I need to use the pump (boon docking) and switch the pump on the solenoid valve will open and allow the pump to deliver water where needed.
The water line is a lot easier to get at and appears to be an easier fix for me.
What say you, pros or cons???
  • One of the things I like about my BSS is it’s simplicity of such things. There is a MANUAL valve that when closed it feeds the house, when open it feeds the water tank and I suppose the house too. Some models I suppose have a more elegant system, but mine is somewhat foolproof. Not a big fan of adding additional things that could go wrong.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
