corvettekent
Jul 27, 2020Explorer
You should see 14.2+ volts within a few minutes of charging. If you only see 13.4 volts you should replace your converter.
You should Google Interstate Batteries and find your local dealer. I bought Interstate industrial 6 volt golf cart batteries that are 235 AH. Costco will have 220 AH batteries.
If you do use 6 volt batteries you will need to run one 4 AWG wire from the Pos. of one battery to the Neg. of the other battery.
