sch911 wrote:
The Aux battery switch is a momentary contact switch, so I think you mean the battery disconnect switch? If the batteries are indeed turned off with the battery disconnect switch they cannot charge, either with the generator, or shore power. They must be connected....
x2
Also not sure what you meant about the 110 plug in. Do you mean it was a 15 amp circuit instead of a 30 amp. That should make no difference to your converter. That should be plenty of power. I don't think you ruined anything. I think your just disconnected. JMHO
