danglo's avatar
danglo
Another black tank leak repair question
There is a small leak from our black tank where the sewer outlet is "supposed" to be joined to the tank. It looks like whatever process was supposed to join the tank to the sewer pipe just didn't take on a portion of the circumference. I want to avoid replacing the tank or taking the trailer to have it "plastic welded". I would like to try:
3M™ Scotch-Weld™ High Performance Industrial Plastic Adhesive 4693H. I would clean up the area I think is leaking with sandpaper and just apply the adhesive. I would appreciate your thoughts.
The picture is taken from below:
The tank is in a 2008 Keystone Cougar 276RLS 5th Wheel trailer.
The tank has a label on it that reads:
Ameri-Kart Corp
R.V.
Model 515
File No. LM33087
Std. No. B45.6
I assume the tank is polyethylene and I am not sure what the material is that it is partially bound to. Perhaps ABS?
Thanks,
danglo
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
