Canadian_Rainbi
Jun 10, 2015Explorer
Actually I could equalise by disconnecting the POSITIVE cable because I have 2 pairs of cables: One pair directly the batteries and the inverter/charger and the other from the batteries to the DC Buss.
I suppose that it might work by disconnecting the negative but I suspect that it would still find a return via the inverter and chassis.
I think Don had in mind using an outboard charger directly to the battery. At least I hope so!
UPDATE: I have configured the Xantrex Prosine 2. Equalise Parameters to I @ 5% C and max voltage to 15.0 more like a top charge for now. Battery is at 14.56 at the moment.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
