fyrflie
Mar 23, 2021Explorer III
dougrainer wrote:
1. HOW do you know it is in lock out mode? Red Light ON?
2. IF in lockout, you need to check for continuity at the tstat and the ECO. They should have continuity. If they do NOT, then which has no continuity that is your problem
3. Atwood had a bad batch of Circuit boards a few years ago and attempted to withdraw all that were out for part replacement and the ones that were on NEW water heaters and suspect ones were supposed to be sent back. There is no way to determine which are good and which were the bad ones. So, just replacing may mean you got a bad one.
4. Are you POSITIVE you have the Tstat and ECO attached to the tank correctly with the spring keeping pressure and contac to the Metal tank? Doug
Why a new regulator and a manometer?
Red light is on when it goes into lockout mode.
I will cycle the water heater again to get it into lockout mode to check the thermostat and ECO.
I replaced the board about 6 weeks ago but will try to check it out. I have the troubleshooting procedure in the RV.
When I replaced the Thermostat and ECO, I used some Silver Paste, apparently to maintain a better contact with the tank. I will clean that off and re-install the parts.
New regulator because the system is 20 years old and I have had issues in the past with other RVs with oil in the lines. And it’s the last part of the system to be replaced.
Manometer to check my gas pressure at the water heater.
I can return the regulator if the pressures check out.
Thanks for the info. I will give it a try and report back.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
