fyrflie
Mar 23, 2021Explorer III
I tried to turn on the water heater and it went directly to lock out mode.(Red light on).
I tested both the Thermostat and ECO while in lock out mode. Both have continuity.
Using the Atwood ( Intermittent Ignition Information Guide), I followed all of the procedures listed.
Following the Potted Channel Circuit Board test procedure, I tested each track as specified.
The Power track and Lamp track both returned a reading of 1478 using a continuity tester.
The valve track had no continuity.
So, can I assume that the board is bad? or should I be looking elsewhere ?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
