dougrainer
Mar 25, 2021Nomad
fyrflie wrote:dougrainer wrote:
What you have is what the defective boards did. Doug
Just installed a new board and it won’t even start.
When you turn the switch on, it goes directly to lock out. Red light goes out then it immediately comes back on.
Could it be another bad board?
Where are you getting the Boards? The problem Atwood had 2 or 3 years ago was they had no way to make 100% sure that the suspect boards were returned from vendors. That means dishonest people could get a hold of the suspect boards for almost nothing and then sell on the Internet or E bay. Most would work just fine a few times. We made sure we returned and purged our stock when Atwood had the problem and had Atwood send us the untainted replacement boards for our stock. You leave the switch ON. Disconnect the module plug from the board and plug in to test at the water heater. Doug
