fyrflie's avatar
fyrflie
Explorer III
Mar 23, 2021
Another Hot Water Heater problem
I have an 2001 Atwood 6 gallon water heater that will run one complete heating cycle then go into the lock out mode. If I shut off the switch then turn it back on, it works fine for another complete cycle then goes back into lock out.
I have replaced the control board, gas valve, thermostat, ECO, igniter, thermocouple and gas tube.
I have 12 plus volts at the board and have cleaned and confirmed a good ground.
Both the Thermostat and ECO switches check out fine with a continuity tester.
When it’s operating, the flame is text book color. I also ran a rag through the U Tube to confirm no blockage or debris.
I did notice a voltage drop in the Red wire. 12.7 volts at board and 12.3 volts at Other end. Don’t know if this matters or not but I am going to replace the connector.
I have a new regulator and manometer coming in the next day or so.
What am I missing?
Any help would be appreciated.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
