MEXICOWANDERER's avatar
Jun 21, 2017
Another Megawatt Upgrade Want To Post Article
Pictures and text.
Is there an easy to use upload service that can retain a created article? The upgrade article would include the entire process divided into chapters.
Easy disassembly & reassembly
How to choose, buy and install a voltage adjustment potentiometer
If needed, how to replace the weakest components (caps and rectifiers) in the Megawatt. This turns the Megawatt into one tough charger.
These things are not nerd techhie grade mods. If you can handle a cheap 15 watt soldering pencil, you can do this stuff so easy it hurts.
But I need a kindergartener's grade upload site to start the process.
Any ideas?
Thank You
  • Naio wrote:
    FYI, google drive uses an enormous amount of ram, even for plain text, and takes a long long time to load.
    There is no requirement to load Google Drive on your PC ! They might make you think there is, but you can always just go to the web interface ( https://drive.google.com/drive/my-drive ) AFTER you have authenticated yourself on Google.
    Upload, download, change permissions, what ever you want.
  • MEXICOWANDERER wrote:
    I can't even offer to send a particular Microsoft Word file to an email address because not everyone can read MW.
    MS Word allows you to export as Rich Text, which pretty much EVERYONE can read.
    If you were using one of the FREE word processors like Libre Office Writer, you could even export it as a PDF !
    If you want some assistance in getting your document "published" contact me.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
