brulaz's avatar
brulaz
Another Solar Setup
Many thanks to all you folks who helped me work out the details of my solar installation. And for the many examples of your craftsmanship.
This link to some pictures may work:
Picassa Album "Solar Trailer"
Some info:
Two 195W panels from "Sunny Power", 32'x60", Voc=44V
Connected in parallel with 2 MC4 Y connectors.
Mounted with double Al 6" angle, 3 SS screws, 3M5200 sealant/adhesive.
Panels at rear of trailer, 10ga cables run on roof to the front. Found a water-tight exterior electrical box to cover the hole through the roof to the interior cupboard. Drilled a hole in the bottom and two in one side for the wires. Screwed and glued (3M5200) in place. The two wire pass-thrus have rubber o-rings, maybe for cable TV? Fit the wires perfectly.
Run wires inside to bottom of front, side clothes closet just over the trailer's pass-thru. "Baby" breaker box with 15A Solar and 30A Battery breakers (Midnite Solar). Rogue 3048 MPPT. 6ga down to trailer pass-thru where it joins up with a PD9260 charger with convenient double bus. Then down and out to batteries on the trailer tongue.
(This is strictly a battery charging circuit, solar or 110V; there are no external loads. The original WFCO remains as the converter.)
Ground to frame from all boxes, Temp and Voltage sensor wires follow same path.
Seems to be working fine so far ... :)
Biggest problem? When bolting the Al angles together and to the Solar Panel frames, about 50% of the "cheap" SS locknuts from Home Depot would jam almost immediately and have to be hack-sawed off. Eventually gave up, returned what was left and used standard zinc-plated bolts, nuts & lockwashers. If I ever get over the trauma, maybe someday I'll replace those with SS.
Sources:
- Solar panels, MC4 connectors, wire with MC4s picked up at 2solar.ca, Markham ON
- Rogue MPPT shipped from Rogue in Oregon
- "Baby" breaker box and Midnite Solar breakers shipped from Arizona Wind&Solar
- 6ga wire, connectors, misc. electrical shipped from DelCity USA
- 3M5200, battery bolt-on fuse holder and 60A fuse PU from WestMarine
- Al angles, screws and bolts PU from Home Depot
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
