full_mosey
Nov 05, 2013Explorer
BFL13 wrote:
Deltran has this take on AGM charging--see adaption 4-step (vice usual 3-step) in this and note the voltages. You do need to click to enlarge
http://batterytender.com/resources/battery-basics.htm/#answer6
None of the AGM mfgrs mentioned anything about temperature compensation? I thought that was at least a common should-be. I find 14.9 and 15.6V unbelievable as common regular charging volts across AGM mfgrs. Educate me!
Is that link an example of Marketing wibbly-wobbly?
P.S., What is the reason for the 14.7V mentioned earlier in this topic?
HTH;
John
