We have been learning a lot since installing our solar this year. I was hoping to avoid a permanent install of a large inverter as we use little power. Today I bought a 150W inverter that looks l...
You would run a new thick wire from the battery bank to an anderson connector. Make sure to fuse it near the battery. #10 wire would work nicely for a 150 watt inverter and would run up to a 300 watt safely.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
