CA_Traveler
Feb 10, 2015Explorer III
Are you sure the coax cables are not reversed? Remove the antenna coax and if the voltage is 12V then you might have a short. Next step would be to measure the current which should determine bad booster or short.
Run a temp coax out the window and up to the antenna to help isolate the problem.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
