n7bsn
Sep 19, 2013Explorer
RoyB wrote:
If you want to keep the BATWING antenna then all you need to do is purchase a new BATWING with UHF add-on assy, It will mount to your existing crank-up assy with two pins. Takes all of five minutes to mount....
Actual testing shows this is probably the best RV TV antenna on the market, outperforming both the King and Jensen antennas
test results as posted to this forum
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
