thelehans wrote:
Our antenna is not picking up channels as well as other RVs near us.
We are thinking there is an issue with the wiring or maybe we need to upgrade the antenna? We purchased used a year ago (2013 model year). Would a replacement antenna be beneficial? Is there a way to test the wiring?
If 'all the other RV's' parked where you are are having the same problems why would you think it's 'your' antenna! :W
Sounds like the location, trees etc is the problem. Look at which way the antennas are pointed on the RV's that claim they have no channels either......and point yours in another direction.
One thing I think some people miss with turning the antenna for digital TV is that you have to slowly "inch" your antenna around to catch the digital signals. Not like in the old days when all you had to do was give the antenna a spin and you'd have a ton of channels signals. The further away the signal is being broadcast the slower you need to turn you antenna so you don't miss it.
