thelehans's avatar
thelehans
Antenna issues
Our antenna is not picking up channels as well as other RVs near us. We are thinking there is an issue with the wiring or maybe we need to upgrade the antenna? We purchased used a year ago (2013 model year). Would a replacement antenna be beneficial? Is there a way to test the wiring?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    First what antenna do you have.
    I have a Winegard Sensar III with Wingman and Sensar Pro. YOU WILL NOT get reception as good as I do unless you have the same set up.. OR spend a whole lot on some very special antennas.
    Jack, not as good. Sensar w/o Wingman or Sensar Pro, not as good. ROadstar, Not as good. in fact _______ not as good. per independent lab testing.
    Now. the coax. usually roof to antenna. can get OLD. and as it ages bad things happen.. Next you have several connectors.
    One at the antenna head
    one at the roof or in the roof.. Short story. That connection in my RV had to be completely re-done. new ends (2) and a new double female (Barrel) connector to join them.
    Then there is the connection on the switch/wall plate (2) and one at the TV as well.
    Plus as others have said. Is there power to the Pre-Amp (light on on the wall plate or the proper buttons pushed and light on on a box with many buttons (Matrix switch).
  • Thanks! We will look into the booster. We've had other RVers come over to help so I'm confident we're doing something right... I hope. Our main concern is college football season!! Can't miss those games!
    Wiscampsin wrote:
    Is your booster on? Does your antenna point the same direction as the ones with a better signal? If it's a Batwing consider installed a Wingman. Took me longer to climb up and down the ladder than it did to install and made a big difference.
    https://www.amazon.com/s/?ie=UTF8&keywords=wingard+wingman&tag=mh0b-20&index=aps&hvadid=78134106147818&hvqmt=e&hvbmt=be&hvdev=c&ref=pd_sl_2cv9q9947l_e
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
