I have a standard crank up type antenna, not sure of make or model, but it does not perform very well. I might pull in 4 channels with it sitting here in my yard. We had friends stay with us last summ...
Check all outside connections for corrosion and a good clean and tight fit before replacing anything. Do the same inside and make sure booster is turned on. You don't say how old your antenna is but the new Winegard Sensar IV is about as good as it gets.
