wa8yxm
Feb 12, 2017Explorer III
Winegard wall plate is not an amplifier if it has a 12 volt outlet, it is the power supply for the amplifier in the antenna however
Now I have the Sensar Pro. Like your wall plate, which it replaces, it is the "Cable/Ant" selector (Except I have one of those elsewhere) it is the power supply for the Rooftop Antenna's buit in amp. but it does not stop there
When the antenna is selected, It seeks the STRONGEST Digital TV signal, and displays both the carrier channel (may be different from what is displayed on your TV) and the signal strength, allowing you to "Aim" more easily
It also, if you push a few buttons, displays ALL signals found and their strength
You can also set a "Channel" to peak with
You can adjust the gain of the internal booster, from a significant REDUCTION to a serious gain.
If you are aiming "Bling" (mounted where you can not see it) you can turn on a BEEPER that indicates the signal strength by sound.
Or you can turn it totally off and choose the park cable inlet.
But no outlet for your phone.
Oh, makes a big difference in what you can see too. More Channels, More Channels.
