Eaglesup's avatar
Eaglesup
Anti-Friction Lubricant
I'm curious if anyone has heard of MAXILUBE ?
or tried it in their vehicle
It's been around for about 20 yrs.
Here's a description of what it does.
The web site is www.maxilube.com
Simply stated, MAXILUBE is a pressure treatment for metal. Friction is created by the moving parts of your vehicle working under pressure. Friction produces heat, MAXILUBE is attracted to that heat and the more heat and pressure the parts produce, the faster and deeper the metal gets treated. The MAXILUBE treatment actually makes the friction disappear, allowing your lubricants to do their jobs much more efficiently while greatly extending the life of both parts and lubricants. Used as directed, the MAXILUBE metal treatment is long - lasting and there is no resin coating or bonded film which can peel or rub off. There is no build up on the metal surfaces and no change of tolerances. The treatment is in the metal, not on the metal. Since friction and wear are a continuous process, the MAXILUBE treatment should be continuous in order to have the least amount of friction and wear possible. Simply add a small amount of MAXILUBE when adding or changing lubricants.
  • "Friction is created by the moving parts of your vehicle working under pressure"
    Really? Learning somethin' every day.
  • (already posted above)
    Honestly I would like to see some type of grading "household" oil like the auto industry uses. Last 5 years or so, lots of new type oil available. When I pick an oil for my use I keep in mind what I want the oil to do. The spray oils with ptfe's I like because it doesn't collect dust as bad as a regular liquid type oil. I think a test such as..."Evaluating Lubricity of Diesel Fuels by the High-Frequency Reciprocating Rig (HFRR)" would be a good way to rate a oil. Guess we have come a long way since horse and buggy days with wagon wheels lube'd with animal fat.
  • I don't know...looks like good stuff!
    https://www.walgreens.com/store/c/maxilube-personal-lubricant/ID=prod6148025-product
  • Sounds like really good stuff. I'll use up my snake oil first, then buy some.
    "The treatment is in the metal, not on the metal" I buy my metal with oil already in it. :)
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
