StirCrazy
Aug 21, 2023Moderator
Itinerant1 wrote:
Just curious if the batteries are working with the predetermined settings in the sealed box why would you want to experiment with them?
easy cycle life. if I can change the top and bottom from 0 to 100% to 10 to 90% that can take your average LfP from 3500 cycles to 4500 to 5000. then if you operate in the top 3rd of that you can go even higher. If I knew I could get into a battery like a chins I may have bought them instead of making my own just to be lazy, but I use the settings in my Bluetooth quite a bit. I have 3 profiles on my phone for setting the BMS, I have a storage routine where the BMS will only charge the cells to 65% of the capacity then won't recharge until they drop below 30% as well my cold temp cut off is bumped up to 3C to be safe. I have a "getting ready to go camping" setting where it sets the bottom at 10%, puts the cold temp cut off back to 1C and charges to 100%. then I have a "camping" setup where the only difference is I lower the top to 90%.
I can limit the battery as I have a 10-day capacity without the solar and unlimited time with the solar, so I decided to make the battery last a bit longer and sacrifice about 2 days' worth of capacity. The batteries are top balanced and topped right up whenever I leave the house on a camping trip.
So basically, cycle life, and the ability to be over cautious on some of your safety settings is the reason.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
