StirCrazy
Aug 22, 2023Moderator
Itinerant1 wrote:StirCrazy wrote:Itinerant1 wrote:
Just curious if the batteries are working with the predetermined settings in the sealed box why would you want to experiment with them?
easy cycle life. if I can change the top and bottom from 0 to 100% to 10 to 90% that can take your average LfP from 3500 cycles to 4500 to 5000. then if you operate in the top 3rd of that you can go even higher. If I knew I could get into a battery like a chins I may have bought them instead of making my own just to be lazy, but I use the settings in my Bluetooth quite a bit. I have 3 profiles on my phone for setting the BMS, I have a storage routine where the BMS will only charge the cells to 65% of the capacity then won't recharge until they drop below 30% as well my cold temp cut off is bumped up to 3C to be safe. I have a "getting ready to go camping" setting where it sets the bottom at 10%, puts the cold temp cut off back to 1C and charges to 100%. then I have a "camping" setup where the only difference is I lower the top to 90%.
I can limit the battery as I have a 10-day capacity without the solar and unlimited time with the solar, so I decided to make the battery last a bit longer and sacrifice about 2 days' worth of capacity. The batteries are top balanced and topped right up whenever I leave the house on a camping trip.
So basically, cycle life, and the ability to be over cautious on some of your safety settings is the reason.
Ok, thanks for the info.
Seems like alot of work but then you have different needs and colder weather.
As far as cycle life why worry about do you really think your going to use it up? I bet more folks will kill their batteries hen pecking them.
Right now I've done 2,502 days (boondocking) of 2,686 days since install. I'm somewhere over 1,000 full cycles and that's 7 years 4 months. A seasonal camper the batteries should last along time.
I guess living off mine fulltime with solar one set of settings. Charge to 14.1v (my 100% SOC), float 13.6, if they get full great and if not tomorrows another day solar might fill the tank. Still use whatever in the 5th wheel including the air conditioner.
ya I figure I will get about 20 years out of mine at the rated 3500 cycles, the problem is, and this is still and unknown, will the batteries age out before the cycle life is up in my situation. so, I am wondering if how we use them can increase the aging out time on them also. some people speculate 10 years of use they will start to age.. personally, I think that is to young for them to age out so this is a long-term experiment, conservative operating range, shallow discharge.10 to 15% in normal situations). the only reason I can do this is because I got 280AH of capacity for about 700US (after conversion) I am also still young if I can make them last 30 to 35 years that will work out perfect for me ;)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
