2oldman's avatar
2oldman
Explorer II
Oct 30, 2015
Any Cotek inverter experts?
I'm moving up to a 48v system. Today I received my Cotek SD3500-148 inverter from Invertersrus. Things are not going smoothly so far.
I'm wanting to hardwire, and the manual instructs me to remove 4 screws and "carefully" pull the AC panel out. Step 1:
Now, the manual says that the panel can be rotated 90° (toward me and down) to allow access to the internal hard-wire port. This picture is an extreme close-up of the removed panel. That green circuit board in the left-hand portion of the picture is attached to the panel I'm trying to remove.
If you look closely you'll see that the white wire is hanging up on the blue wire which makes it difficult to pull the panel out much. I don't want to force it. Has anyone dealt with this?
I wouldn't bother hardwiring if I didn't think I had to, but this inverter will be running everything, including a/c if possible. The rating of each of the standard outlets is 20a - which may work. However, if I could wire them in parallel (use 2 plugs into the standard outlets and wire parallel), I could skip this hardwire hassle. This sentence seems to say that -- Page 21: "Note: if input current over than limit current, please adopt choose to Outlet Adaptor with 2 sockets" Is that what it says??
I'm in contact with a local man who's fronting for their tech support, but I thought I'd pose it here just for fun. Nothing like a Taiwanese to English manual.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
