2oldman's avatar
2oldman
Explorer II
Oct 30, 2015
Any Cotek inverter experts?
I'm moving up to a 48v system. Today I received my Cotek SD3500-148 inverter from Invertersrus. Things are not going smoothly so far.
I'm wanting to hardwire, and the manual instructs me to remove 4 screws and "carefully" pull the AC panel out. Step 1:
Now, the manual says that the panel can be rotated 90° (toward me and down) to allow access to the internal hard-wire port. This picture is an extreme close-up of the removed panel. That green circuit board in the left-hand portion of the picture is attached to the panel I'm trying to remove.
If you look closely you'll see that the white wire is hanging up on the blue wire which makes it difficult to pull the panel out much. I don't want to force it. Has anyone dealt with this?
I wouldn't bother hardwiring if I didn't think I had to, but this inverter will be running everything, including a/c if possible. The rating of each of the standard outlets is 20a - which may work. However, if I could wire them in parallel (use 2 plugs into the standard outlets and wire parallel), I could skip this hardwire hassle. This sentence seems to say that -- Page 21: "Note: if input current over than limit current, please adopt choose to Outlet Adaptor with 2 sockets" Is that what it says??
I'm in contact with a local man who's fronting for their tech support, but I thought I'd pose it here just for fun. Nothing like a Taiwanese to English manual.
  • Separate are better for mean time between failures. Trouble shooting is much easier, and failure of one part does not necessarily end a trip.
    I agree at higher input voltages the pool of available inverters is small--and even smaller when you want high wattage coming out the 120 volt side. I was unable to find a quality 4000 watt 12 volt input inverter and so ended up with the Magnum at 3000 watts. Sometimes I wish I had gone to a 24 volt bank as then Magnum would have a useful unit.
    However, I absolutely love the load support feature on the hybrid Magnum inverter charger. I've used every day for the last four weeks. Victron also offers that feature.
    I did keep my OEM converter as some (but not all) GFI outlets don't "like" the Magnum.
    When I tried double conversion using the PD converter with the Magnum, it blew the reverse polarity fuses on the converter as soon as I used a large load. However, that was with the ten year old flooded batteries.
    I compromised by using just one outlet on the Magnum for heavy loads, and turning the converter off when I did so.
  • pianotuna wrote:
    A Victron Inverter/charger
    Victrons are nice. At higher voltages it's harder to find products.
    I was also considering the Outback IC, but with its controller it's well over $2 grand. That's not so bad, but its weight at 64lb was a deal-breaker for me.
    I'm starting to like your idea of having separate components.
  • A Victron what?
    I can try running the air, yes. I'm feeling a bit bummed by this unexpected hardwire hassle. I don't know how my coach will react to plugging into GFCI outlets.. maybe I don't wanna know.
    Always something!
  • Hi 2old,
    At that price you are getting close to what a Victron costs.
    Can you test the new one (i.e. will it run the air) before you return it just by plugging in briefly?
  • Connect fan toward device if observe fever? Chinglish 101?
    If it were me, I would wait rather than cause a Laurel&Hardy grade involuntary disconnect. Get the name of the tech so he can give the monkey a ride on their nickel if the job goes awry.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
