tommymsw
Mar 05, 2018Explorer
MEXICOWANDERER wrote:
Motorhones do not have a house fuse for the running lights
They use a chassis fuse. Find and test every Ford, Chevy, Dodge, chassis fuse.
Clearance and running lights are on the SAME fuse.
So SOME of the lamps working cannot be a fuse issue
Go to the string of lights up close and personal
Start removing lenses and housings from the body
One lamp assembly will contain 2 extra wires.
Do you have power at that lamp
So you have chassis negative at that lamp
I opened up all 5 lights. I replaced all the bulbs even though they appeared fine with new LED bulbs. No double set of wires. All had TWO wires going to them... White and black.
Front clearance lights still do not work. Every other clearance and marker light works. Wires to the lights all seemed fine. No noticeable breaks.
I would not care (not sure why you need them) but I don't think it will pass inspection.
