tommymsw
Mar 05, 2018Explorer
D.E.Bishop wrote:
JD is partially correct, but gave the wrong chassis(your booboo), you need to go to winnebagoind.com and go to the section for schematics and manuals.
There are 2 Sections to the electrical schematics. The Winnie section and the Ford section.
Look for a schematic with the running lights and using the code there to check what the wire is connected to on both ends.
It's a dective game but when you learn the rules, you'll have it made.
Check back after you down load and look at them. If you still have questions, let us give you some help.
Not sure what you mean. It seems to take me to the same place that JD said. I don't see any part for "Ford" as an option. Just the spot for the 35B.
I have been here before and the wiring diagram doesn't help "me". While it did show me all kinds of things I needed to know (like what switch does what), I am unable to understand how it shows me what fuse is what. I can trace the line for the lights to an "area", but it does not seem to be the fuse box.
