wa8yxm
Mar 06, 2018Explorer III
DO the side marker and rear marker /clearance lights work? If so the fuse is good, Same fuse, you have either a Ground Fault (Suspect #1) or broken wire (#2) or the bulbs are not as good as you think (Suspect $ 3,000)
THe fuse will be in one of two or three places
The main CHASSIS fuse box (labeled)
The aux panel (you shoudl have a label for that)
or part of the headlight switch (have not seen that done in a long, long, time)
But if the rest of the lights work.. I do not think it is the fuse
You only have two fuses for outside lights
The other is the porch light, lighted handle and work light, that is in the HOUSE fuse block.
