hbillsmith
Jan 22, 2018Explorer
wa8yxm wrote:
Ok, far as I know only HONDA has the "Extended Run Tank" feature...
Almost correct except a little more clarification is appropriate. Honda's Inverter/Generators have a factory built-in fuel pump and a pressurzied tank feed. For that reason, for the most part a modified fuel cap will suffice to add an external tank.
Champion and others use a gravity fed internal fuel tank and in order to add an external tank one must modify the inverter/generator to add a vacuum fed fuel pump (similar to what's used on most lawn mowers).
Pinellas perfected the parts and process for adding the fuel pump to Champion and others. This message thread has a video link and instrucutions and DIY parts list should one want to do so.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
