Old_timer_Dave's avatar
Sep 24, 2019
Any old Dodge mechanics online here
1978
I have an old dodge 1 ton with duel rear axle.The front axle is a 3,300 lb rating. According to the parts list for that year the disk and hub was #4037876. All other versions used a single axle and different disk and hub #4037875.
What was the difference,larger in diameter and bigger offset on the caliper. If the Mounts and spindle are the same is it possible to use the downgraded single axle brake set up
realising that there will be a trade off in braking efficiency.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
