KendallP
Oct 01, 2013Explorer
MEXICOWANDERER wrote:
Easy. Connect them ALL to the strongest in the herd. Monitor voltage over a period of a week. If it droops then you'll need to fall back five and punt.
Personally I do not like tandem-ing high frequency devices. Like coupling an oboe with a cello. Even though a waltz may start, pretty soon they both regress where they don't belong - into jazz, and you in a heap o trouble. If you are a technocrit you can try adding a .47 uf capacitor - sort of like a midget conductor to the symphony.
Good Lord, Mex! Is that some kind of broken Spanglish you're a' speakin' there??? Holy cow! ;)
PT makes a good point, but the OP says he already has the Battery Tender.
Again, BFL can testify to the well documented, successful use of multiple, high frequency chargers in parallel.
Mex,
Is the Battery Tender Plus a high frequency charger?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
