BFL13
Oct 01, 2013Explorer II
rottidawg wrote:BFL13 wrote:
Not sure about the actual correct answer, but first--can't you just unplug the camper from the truck? You aren't driving at the time you want to do this.
That would be the easy answer, but my camper is on full time and the plug can't be accessed.
I suppose I could install a cut off switch to the camper if I HAD to.
You can pull the Stud fuse in the truck (under hood by battery) that works the "charge" pin (#4 in a 7-pin) in the truck/camper connection
I can imagine times at home you might want to keep the engine battery on a float while doing chores in the camper, then returning the camper batts to float when the Iota gets back to that later.
Unfortunately, I don't have any pictures of K's sister like I do of Mena's the mermaid, or else this would be a good time to produce them! :)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
