KendallP
Oct 03, 2013Explorer
smkettner wrote:
...Both (or all 18 :) )... will just drop out as the voltage meets or exceeds the set points.
Think if you had 18 chargers rated one amp each and voltages set at 12.5 to 14.1 at 0.1 volt intervals. You get 18 amps until battery voltage hits 12.5 and then 1 amp drops out. Then at each .1v another charger drops out until the last charger holds the battery at 14.1 volts. The other chargers just drop out of the process. And no harm to any as all these voltages are in spec.
LOL!!!
Glad you were able to make good use of my "18" quote, there, SMK. :)
I guess I'll have to add my sarcasm emoticon from now on. Ol' MEX seems to get away with it. Perhaps I'm just not quite as skilled. Hope I don't need another 50 years to get that sarcastic!
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
