MEXICOWANDERER
Apr 23, 2015Explorer
- SEALED corrosion free connectors
- No water to add ever
- Charges faster discharges at a higher rate (kilowatts)
- Much lower self-discharge rate when disconnected
- Greatly reduced incidence of plate hardened sulfation
- Will not freeze nearly as easily
- Can survive repeated deep discharges better
- More expensive
- Heavier weight per amp hour
- You get what you pay for
That being said, if any of the positives appeal to you or if any of the negatives turn you off, then it's decision time. Your "Never Boondock" should be a significant influence on your decision.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
